Frankdtank
- Joined
- May 5, 2012
- 51
Re: Volvo penta 3.0 with SX-A drive leaking....just out of warranty
I posted two replies back top back, this is the first one...
I got 3lb slide hammer/puller kit and i have been knocking away at it for awhile, but the bearing won't budge.
Any ideas?......... I am actually considering a fancy puller off of ebay that is designed to do the job.
On the drive side of the problem I have removed the bearing carrier from the drive. What is the proper way of removing the shaft/u-joint assembly?
I am referencing to the diagram below:
U-Joint And Bearing Carrier SX-A, DPS-A - 7746270 - Volvo Penta
I am guessing removing snap ring #6 and screw #4 should allow for removal ?
Also the parts on the drive side of the bearing carrier look great and the only thing I am thinking about replacing is the seal #12.
On the engine side I hope to get away with a new seal #7 and if needed a bearing #8.
Since the u-joint/shaft assembly is only sold as one piece assembly ($450 at volvo), I decided to soak the u-joint in some rust remover. It is looking pretty good, but what do I know? Is there an outside chance of re greasing it and being able to save it or is it toast?
I know these are a lot of questions, but it's my first time, so I thanks for all the help..
