Volvo Penta 3.0
Amans
Hi, my Volvo Penta has been running loud and seemed like water was not running through the engine. I replaced the impeller and later the entire fresh water pump. Neither solved the problem. Not sure if it’s something with the serpentine belt around the water pump or something completely different. I attached a video of engine running. Any advice would be great.
Start with the hose fitting on the drive that connects the hose to the transom shield which feeds the raw water pump
That fitting is part of the annual PM where you pull the drive and inspect things
