volvo penta 3.0L exhaust manifold leak test
djnordeen
Can I do a test on a volvo penta 3.0L exhaust manifold for leaks when it is cold out.
Michigan temps are just above freezing in the coming weeks.
Using Acetone to test.
Thanks, Dan
Lou C
Yes just be careful acetone is very flammable
Lou C
Very good now you just have to dress the sealing surface between the manifold & exhaust elbow. You can use a mill bastard file or a sanding block with 80 grit sandpaper. Then check the flatness with a straight edge & feeler gauges you want it to be less than .003” thickness variation. Preferably like .001”, that’s what I got with new Barr Marine parts on my 4.3 V6.
