- Joined
- Jul 23, 2011
- 51,875
if the seal isnt there, you will eventually kill the pump as the bearings are now exposed to water.
did you ever check the raw water inlet fitting on the outdrive? the one that the supply hose is attached to on the outdrive end? they fail on volvos, and should be replaced when you replace bellows every few years.
