Volvo penta 4.3 AQ430 changing outdrive oil
orion208
What is the procedure for changing the outdrive oil on this boat?Can the oil be refilled from the top or must it be filled from the bottom like an outboard?Thanks.
orion208
Re: Volvo penta 4.3 AQ430 changing outdrive oil
Sorry for the double post.Can someone out there explain the various ways water may get into the outdrive oil to make it appear whiteish,I have been using the boat for quite sometime and just decided to check the outdrive oil it may have been this way for a while,but it seems to run great,Thanks Star!
pine island fred
just did this last week on my friends volvo. what we did was drain the oil, install a new o ring on the plug. reinstall plug. our best shot was refilling thru the dip stick hole. first we removed the cover on the back ( 2 long straigh slot screws ) and removed a vent plug. then with a small funnel we poured in 2 quarts of 90 weight. reinstalled the vent plug and slowely topped off the gear case. should not take much more unless it is a duoprop.
orion208
Now I am really confused, Fred.On another post it was said the outdrive takes 10w30 or 10w40 not 90 .The actual motor is a Volvo Penta 430B single prop 1992 the decal on the leg say's either sd cotrim cd cotrim.if that helps.
kayakndave
Just did this on my 1988 290 SP outdrive. Don't know if yours is similar, but mine has a dipstick on top the outdrive that you check the fluid level with. In order to fill the outdrive, you have to remove the back cover, and remove the fill plug in order to fill/ or top off. Down at the bottom of the outdrive is the drain plug. The manual on mine says to fill with 10W-30, however my mechanic just replaced a few seals, flushed the outdrive, and he added 90W synthetic, told me it's great stuff for the outdrive. I sure hope so!
pine island fred
woops. just took the clymer manual out. recommended lube for models 100 and 200 is 90 weight. all others have 10w-30 or 40. when we drained it, it was full of 90 weight, and never checked. could be the reason we have to replace the u-joints after 1/2 hr. of operation. no telling how long the wrong oil was in there. damn used boat, can never tell what is going on. cant find a 430b listed. models of outdrives show 100-200-250-270-280-290-sp-duoprop. hope someone else can help.
orion208
I finally got hold of a manual for the 91 4.3 penta it say's single prop same oil as engine dual prop sae 90 if that makes any sense.Well since I have the single prop I guess I will go with 20x40,hope thats right.
Dunaruna
Same as engine, 10w30 or 10w40. That is the specification in Seloc, Clymer and genuine VP manuals.<br /><br />Aldo
orion208
Thanks for your help Aldo!
nu2boating
i just purchased the same motor and out drive can you tell me where to get a manual and if you know can you tell me how to change the engine oil and if anyone can give me any other advice that might be necessary
