manuel0307
Thread starter- Joined
- Jul 12, 2020
- 8
Hi from Germany,
I have a problem with my engine especially with the ignition system.
The engine and the ECM brings the fault code 41 with the following discription:
+ (41) EST A Fault
+ (41) EST has open circuit
The engine starts normal but when reaching the operating temperature it is no really misfiring but it stops (may be in Cylinder #1)
Because of the behavior I changed:
1.) crankshaft sensor
2.) camshaft sensor
3.) rotor
4.) ignition coil + ignition module
4.) distributor cap
5.) ignition cable (8+1)
How can I evaluate the open est circuit?
AND
Waht does the error on cylinder #1 means?
+ (41) EST A Fault
2.) camshaft sensor
3.) rotor
4.) distributor cap
AND
