About 4 months ago, I had a leaking exhaust manifold and ended up with water in cylinder #5 on my Volvo Penta 5.7GS engine. Fortunately I had fresh water flushed the engine so at least it was not salt water in the cylinder. Upon trying to start the engine I heard a hard clack noise and we thought the engine might be frozen. To make a long story short, I said a prayer and dumped in some Marvel Mystery Oil to help prevent seizing, I pulled the port side head and one of the valves in Cylinder #5 had broken off and was laying on top of the piston. I had the valve replaced for about $120 (in West Palm Beach, FL) and after putting everything back together (with new exhaust manifolds) we started the boat on just the 2nd try.
Amazing, now he thinks he's a mechanic... well, not really... I've got a lot to learn (this forum has been great). Fast foward a month later and the boat is tied up in our slip in Boca Raton, FL with an engine that runs fine but rocker arms were clacking a bit. After taking off the valve cover and re-adjusting the rocker arms, I tried to start the boat a week ago and the starter was bad. Replaced the starter, first with the wrong one from West Marine (high performance model which does not work with my engine) and got the correct one from a local shop (Cable Marine in Ft. Laud). The new starter works great (what a nightmare changing it though)... now the starter engages and turns the engine but it will not fire the engine.
A friend unsuccessfully tried adjusting the timing and even spraying starter fluid in the engine but it refuses to start. We do get spark, not sure if it is "good spark" as my marina mentioned this morning (blue color = good spark, orange/yellow = bad/weak spark). I'll check the spark condition and report back tomorrow. We suspect the issue now may be a flakey starter coil. Not sure if there is a resister on the coil but I get an 8Volt reading across the coil vs 12 at the battery. We also bypassed the ignition keyswitch with a jumper to the battery and that did not start it either.
Any other ideas why it might not be even firing with the starter fluid being sprayed into the intake? Given a new coil is about $50 I will probably just change it and see if that fixes the problem but given I do have spark (good/bad to be determined later), it seems the engine should at least fire up with the starter fluid.
For reference, the following are the details about my engine, etc.:
Motor: 5.7 PEFS sn 4012003534
Engine Number: DPSM1
Outdrive SN=4112090879
Transom Assembly=TSKSX-M3868844
Does anybody out there have the procedure to adjust the timing properly for this engine?
Thanks for any ideas and for all the tips and advice on this forum!
-Mike
-Mike
