Volvo Penta 5.7 GXi-C cranks but won't fire
PcolaBeach
Good morning ... I'm hoping to receive input on this issue from the more experienced personnel within the Forum. Thank you to all in advance. I've read so many posts on various forums that simply ended without conclusion, one thing I will commit to is closing the loop on whatever the solution turns out to be.
The engine in question is:
Volvo Penta 5.7 GXi-C Raw Water Cooled
Serial Number 4012062213
Production Number 3869137
MEFI Assembly Number 57IAFM/02HT01 3861773
Boat - 2002 Cobalt 240
Symptoms:
1. DTC Code 81 is present - We don't have a scan tool. This was obtained via the paper clip and counts 1-2, then 8-1, then 1-2
2. Cranks fine off the starter motor but will not fire
3. Fuel Pumps do not go through their normal 2 sec prime / stop as ignition key is placed to on
4. Fuel Pumps do not operate during cranking
5. Will fire and idle well with an ounce or so of fuel added through throttle body
6. Audible alarm is a persistent, non-stopping on off on off, etc. once the key is in the on position regardless of what other action is being done
7. Boat has not run in 18 months - fuel in tank has been replaced
Actions taken:
1. Although batteries are 6 months old, batteries have both been recharged and read 12.6v dc
2. Prior to my involvement, ECM's were exchanged with a supposedly good one although I wasn't around during that testing
3. HP fuel pump has been replaced due to recommendation from a previous marine mechanic.
4. Fuel Pressure regulator removed, screen sprayed clean with carburetor cleaner
5. Batteries grounds all indicate less than 0.5 ohms
6. ECM grounds from J1 connector pins 13, 28, 29 all tested good at 0.2 ohms
7. Verified and tested all 5 15A & 20A fuses at relay terminal
8. Verified and tested fuel pump and ignition relays - 0.2 ohms with contacts closed
9. Continuity tested SB/Y wire from fuel pump relay terminal 85 to J1 connector pin 6 - 0.2 ohms
10. Continuity tested Y/GN fuel pump wiring from relay contact 87 to each pump harness connector - 0.3 ohms or so
11. Continuity tested SB fuel pump ground wiring - 0.3 ohms
12. Added clear tygon line to pump assembly, and at fuel pump relay terminals jumpered 30 to 87. Fuel Pumps each operated continuously until jumper was removed
13. 12v dc and a solid ground have been confirmed at both the crankshaft and camshaft sensor harnesses. Signal voltage from each sensor has not been confirmed as I did not have a sewing needle to back probe for this voltage.
Over the last several weeks, I've been helping a friend troubleshoot several items on this engine. Although many hours have been spent trying to find something of a scenario comparable within the VP Forum, I've not quite been successful. I've been using Workshop Manual C EFI Diagnostic 2(0) for troubleshooting logic as well as the appropriate wiring diagram. I'm not a Marine Mechanic although I spent a career managing electrical power plants using aero-derivative engines as the prime mover for power production and enjoy this type of troubleshooting on EFI auto engines.
Given the symptoms and testing described above, it's my opinion the fuel pump relay ground at J1 pin 6 is not being commanded closed to ground by the ECM. That being said, I don't know if this is because of a "problem" with the ECM or a separate permissive issue the ECM is sensing that results in the ECM electing to not complete the ground circuit for J1 pin 6 to FP Relay contact 85. I do appreciate the extra sets of eyes and knowledge. Thank you!
DTC 81 is for many things
DTC 81 - Crankshaft Position (CKP) Sensor Circuit Fault ..................................................... 300
DTC 81 - Camshaft Position (CMP) Sensor Circuit Fault ....................................................... 304
DTC 81 - Camshaft Position (CMP) Sensor Circuit Fault (cont.) ........................................... 306
DTC 81 - Fuel Pump Relay Driver Circuit High, Low or Open ............................................... 308
DTC 81 - Fuel Injector Driver A Circuit High, Low or Open.................................................... 312
DTC 81 - Fuel Injector Driver B Circuit High, Low or Open ................................................... 314
DTC 81 - 5 Volt Reference Circuit Out of Range ..................................................................... 316
DTC 81 - Depspower Circuit Out of Range.............................................................................. 318
Your on the right track. You could jump across the relay 85 to 30 and see if the motor runs. My guess is it will not, and therefore the ECM is suspect.
If the tachometer shows 300 or so rpm when cranking, then the CPS is working
Would be nice if you had another motor which you could install the ECM on to check it out. That said, yours could possibility be repaired, but your still talking some coin to do so
PcolaBeach
Thank you for your response. We will need to confirm the tach readings next time a start is attempted. Very good to know if we do get the rpm's then the crankshaft & camshaft sensors have been eliminated.
I do intend to do some additional testing on the 5 Volt Reference Circuit Out of Range and the Depspower Circuit Out of Range diagnostics procedure.
Regarding your suggestion to jump across the relay 85 & 30 to see if the motor runs, I'm not sure I understand that. I have jumped across 87 & 30 and the fuel pump motors did run. Item 12 of Actions Taken from initial post. Would you please explain a little more what you had in mind and how to execute this suggestion? I'm probably just missing something with what you're thinking.
If I correctly understand the ECM's role in closing the ground circuit to 85 coinciding with turning the key to on, wouldn't a DMM continuity test with a probe at 85 to GND prove whether the ECM is completing the ground circuit?
Thank you!
Your correct, I was thinking and didn't get my thoughts straight before posting. You should be able to use a test light and go across 85 and 86, then when the key is ON it should light. Or if using a meter, see if zero ohms show
You have done the testing correctly (30 and 87) and mentioned in first post, so my mistake
PcolaBeach
Very good. I'll post those results after the next set of tests. I'm assuming there is value in going through the 5 Volt Reference Circuit Out of Range and the Depspower Circuit Out of Range diagnostics procedures for DTC 81 unless you think otherwise.
On the very rare occasion and only after disconnecting the batteries, J1 & J2, main cannon plug at the rear and the 3 connectors at the relay terminal then reconnecting all, the fuel pumps will go through the prime cycle maybe once or twice as the key is turned on so I've not completely ruled out some kind of an intermittent trouble. Meanwhile the audible alarm never stops beeping on & off.
That said, the ECM visually is kind of 'crusty' looking. Also wonder if there is any value in splitting the ECU case for a simple visual inspection looking for water intrusion, burning, etc. We're considering sending the ECM to OBD Diagnostics, CA for an incoming, as received test and are interested in feedback, unless it violates forum rules, regarding their performance.
Much appreciated!
This is good to know. I don't see the ECM working and then not working. Check the 12V and 5V supplies to see if one of them is falling below reference voltage. It could very well be that one of the sensors is shorting out and causing the ECM to have an issue.
Posting test results and other such is of no concern and most all info is welcomed. More info the better, even if some does not pan out.
You could open it, but for the most part I don't see it as helping, but won't hurt.
OBD is a good place, and Bob is tops. I bought the MEFI burn software from him, and have a copy of my bin file. So if mine ever goes out, I can re-flash the new ECM
PcolaBeach
Excellent! Bob and I have exchanged a couple of emails. It's a scorcher here in the Pensacola area with little shade at the boat so it might be a few days before I have any new information to share. In the meantime, Happy Memorial Day to all. Thanks AllDodge for your interest.
QBhoy
Just me trying to keep it simple but are you getting fuel at the test nipple when ignition is turned on ? When you say you don’t get the usual pump priming, you mean it doesn’t come on at all ?
PcolaBeach
So, as a follow up to earlier action items, here are a few updates from some addition testing today:
1.) Tachometer read 100-150 rpm's while cranking
2.) Resistance measured from the fuel pump relay terminal #85 to ground was a.) infinite with key off and b.) 0.420 megohms with key on. I find this interesting that even though the resistance did not go to zero, the ECM was 'attempting' to close to ground given the reading change. Under initial actions #9, continuity tested SB/Y wire from fuel pump relay terminal 85 to J1 connector pin 6 found as 0.2 ohms
3.) With J2 connector removed and Ignition On Engine Off, confirmed 12.68 V at J2-1
4.) Performed DTC 81-5 V Reference Circuit Out of Range. Step 2 measured 0.14 V at J2-2 which did not exceed the 5.1 V limit. Is 0.14 V a typically expected value or is anything less than 5.1 V an acceptable reading?? Step 3 did not find any resistance measurements between 0-2 ohms during continuity checks between J2-2 and all other circuits of the ECM J2 connector. This all results in replacing the ECM via step 9 View attachment DTC 81-5 V Reference Circuit Out of Range 05.28.19.pdf
5.) Performed DTC 81-Depspower Circuit Out of Range. Step 2 measured 0.42 V at J2-17 which did not exceed the 5.1 V limit. Is 0.42 V a typically expected value or is anything less than 5.1 V an acceptable reading?? Step 3 did not find any resistance measurements between 0-2 ohms during continuity checks between J2-17 and all other circuits of the ECM J2 connector. Again, this all results in replacing the ECM via step 9 View attachment DTC 81-Depspower Circuit Out of Range 05.28.19.pdf
Another observation was that after reconnecting the J2 harness to the ECM, the fuel pumps attempted to prime only one time. Key was turned on and off a handful of times yet the pumps never ran again.
I'm not really sure of the proper next step. Cranking speed was less than the expected 300 rpm and the voltages measured at J2-2 and J2-17, although lower than 5.1 were a lot lower. Whether that's acceptable or not, I don't know.
Any feedback is appreciated. Thank you!
PcolaBeach
To QBhoy, yes that is basically correct. Under a normal lineup, the ECM is not closing to ground the J1-6 to fuel pump relay terminal 85 circuit.
QBhoy
Sorry if I missed you saying. Possible the fuel pressure regulator is at fault ? Sorry if I’m still keeping it too simple.
QBhoy
Sorry. Just saw you had it out. Would still be maybe suspecting that perhaps. Especially now that the pump has once tried to run ?
PcolaBeach
Thanks. It's not been eliminated, however, being downstream of the fuel pumps, I don't believe the fuel pressure regulator is really in play at this point in the troubleshooting.
QBhoy
You’ll likely know better than I but I assumed that the fuel pump and when and how it runs on a common rail system...must have a means of control on the discharge or pressure side of the pump.
Both J2-2 (5V ref) and J2-17 (Depspower) should read 5V the way I read/understand the guide. Getting less the 5V reference can cause the ECM to do all kinds of strange things and throw codes. This is why they want all the 5V sensors/fuses disconnected to see if power comes back up, if it doesn't then its inside the ECM
PcolaBeach
Thanks AllDodge ... So, for each of the 2 tests performed yesterday, the voltages measured at J2-2 and J2-17 were made only with the J2 harness disconnected and ignition on. Only resistance measurements were made in step 3 after the F3 & F7 fuses, MAP & TP harnesses were disconnected during the 5V Ref. Circuit out of Range tests or in step 3 after the F3 & F7 fuses, CKP & CMP harnesses were disconnected during the Despower Circuit out of Range tests.
Is there another test I'm missing that disconnects all the 5V sensors/fuses to see if power (assuming this is J2-2 and J2-17) comes back up. I'm not able to find this procedure within the PFI diagnostics section. Thanks!
muc
"Retired" Association of Marine Technicians...
Don't know how much I can help with this because I would only use a scan tool. But I'll try.
J2-2 should have 5v +or- .2v
J2-17 should be battery voltage
Not sure how your measuring J2-2 and J2-17 but here is how I would do it without a scan tool.
Unplug MAP, TPS, 2 wire temp sender, CAM and CKP. Make sure all 5 are unplugged.
key on
+ voltmeter lead to A in TPS plug, - voltmeter lead to B in TPS plug. Should see 5 volts.
key still on
+ voltmeter lead to A in CKP plug, - voltmeter lead to B in CKP plug. Should see battery voltage.
The OP's link in previous post and my manual shows the same
PcolaBeach
key on
key still on
Thanks Muc. This should be easy enough to measure. I'll report back after these two measurements have been obtained. On the assumption that I do get the desired 5V at the TPS & 12V at the CKP plugs, would there be a consensus as to sending the ECM out for an incoming test?
