Yes, the hoses that attach to the impeller housing are of two different sizes so impossible to make the wrong connection. I was wondering if the pump could draw water from a tub of water. OK, that was my mistake thinking it could.
I pulled the impeller and although it did not seem damaged, i measured it and it's diameter was 2 3/16". The diameter of the original impeller and also the new one I have replaced it with measure 2 5/16". Don't know if that makes a difference. Also, the reason I replaced the pump housing was I noticed the old one had slight grooves worn into it.
I visually checked the hose from the pump back to the drive pickup and have not detected any holes or cracks. I attached water hose to engine connection and water flows back out the drive pickup.
Now that I have a new impeller installed, detected no leaks in the system, what is the best way to test it? Will attaching flush attachment to outdrive do it or do I need to get it to the lake?
