Volvo Penta 5.7L in Glastron GX-235 overheating in an odd way
BillyL
Tech Specs: 2006 Glastron GX-235, Engine is a I/O Volvo-Penta 5.7L Gl-E, Outdrive is an SX- M 1.43, and the Transom assembly is TSK SX-M.
Problem: Engine runs at completely normal operating temperatures EXCEPT when I trim the outdrive up (remaining between the stops, of course, and completely within the normal tilt-trim range). When I trim it up, even a relatively small amount, the engine temp will run pretty promptly up to 200 and the alarms start. When I tilt the drive back down fully, it promptly returns to normal operating temperatures. So there's a direct correlation there, and routine causes like thermostat, impeller, main water pump, gauge operation, etc can be ruled-out.
It seems like something along the intake path is getting restricted when the unit tilts up. So, what could be causing that? (One other note - this engine was R&R'd a year ago, so there's no debris in the engine or anything.... but, could something have been done wrong possibly during the engine reinstall? And if so, where should I look for the likely problem)?
Welcome
Can you post a pic with drive all the way down and on the trailer. Want to see how the vent plate aligns with the keel
My guess the raw water hose fitting on the drive
BillyL
Welcome
Will do and I appreciate the quick response... But it will likely be a couple weeks until I can. We left on end of summer vacation for a couple weeks right after I posted this, so will need to take that picture when I return and will post it for you then.
QBhoy
Could be the hose kinked…but I’d also suggest not to rule the impeller out so easy. A perished impeller may just be able to draw water from a fully submerged intake on the drive, sitting deep in the water…or at an angle allowing a fuller flow when underway…but ain’t quite man enough to pull water when there is less of a head of water pressure or the intake is at a less than full on angle to allow a fuller flow when underway. Even a perfect impeller will take less water up when the drive is raised, compared to a fully lowered drive. Yours might just be on the very edge of its function. Just a thought.
