Lou C
- Joined
- Nov 10, 2002
- 13,446
but did you test it?
a 160 stat should start to open at 155-160 and be fully open by approx 165 you should use a radiator thermometer to verify and measure how far it opens, if it opens too late or not far enough you can have running too hot issues
as Ronald Reagan once said trust but verify
also:
what do the passages in the stat housing look like? Make sure there are no bits of old impeller vanes in there. Make sure the bypass port is open....
besides testing for air getting into the cooling water flow, you may need to test for exhaust gas getting into the cooling water. This is a tough to track down cause of overheating the bad news is that it is caused by leaky head gaskets.
also:
