VOLVO PENTA AQ 280 NO WATER GETTING TO PUMP NARROWED DOWN
fish4boats
Ok I think I have this narrowed down. It's a 1978 chris craft cruiser that's overheating. I unhooked the mainline to the sheerwood pump leaving only the water inlet hose to the bottom of the sheerwood. I started the boat leaving run for a very short time but no water pumped out of the pump.
What I've done and checked
1. New impeller put in. But one brand new one up already.
2. The inlet hose is fine no tears or cracks.
3. All hose clamps are tight
4. Replaced the thermostat "old one came apart
Initial problem
But started to overheat slightly then overheated unless not underway and at high rpm.
Picture inside of motor compartment shows a missing hose to rwp inlet. I just removed this hose. It was connected prior to
Questions
Does entire cooling system need connected for the suction of the water or should it pump with only lines from outdrive to raw water pump inlet. Should it pump out of the out of the rwp.
​The bottom nine pictures are the newest pictures
Any help would be immensely appreciated
72fj40
Check the hose on the outdrive that connects to the transom plate, that is a service item along with the water neck and gasket mounted on the o/d that it attaches to. The water neck is designed to detriorate. You won't get water if it sucks air in that area. I would think the pump should pump if the out is not hooked up. Something like 9 gal a minute.
If you're running it muffs, there's a hole in the bottom of the o/d that needs to be blocked off.
Yep, check the inlet casting. Most likely it is corroded to nothing
fish4boats
Do I need to pull the outdrive off. The hose from the o/d to the transom plate is fine
captmello
Your description is confusing. When does it overheat while in the water? at idle? When the boat is on plane?
Does this cool it down every time? running at high RPM?
fish4boats
It heats up on plane and when idling. Usually cools down when running at higher rpm
