Volvo Penta AQ125B Water Pump Weep Hole Leak
Hello all, I have been searching for a water pump for my AQ125B but sadly am finding that part is out of production. Having said this, does anyone know if there is a rebuild kit for this pump and/or if there is a different pump that will work with this motor.
Thanks!
dypcdiver
Sounds like you need a new one of these [h=1]VOLVO PENTA SEALING RING (827247)[/h]
Thanks for the response. I've looked that part up. Is this sealing ring for the raw/sea water pump? I'm actually needing help with the circulation pump. I typed the wrong thing in. I forgot its called something different on a boat then a car. Sorry about that.
Anyway, is there a rebuild kit or sealing ring for the circulation pump that will fix this issue?
Thanks again
Thanks for the links. So it seems either way I'll be spending $500 for this circulation pump. I've found a reproduction pump for it on ebay. Even it's $561 but I suppose its better then having to retrofit an auto pump and end up spending around the same amount.
Thanks again!
