TrevorStott
Thread starter- Joined
- Nov 6, 2018
- 83
I tested the compression on the motor this weekend and found my rough idle culprit. Here's the results.
Cylinder 1: 3psi
Cylinder 2: 150psi
Cylinder 3: 120psi
Cylinder 4: 150psi
#1 is a real problem, I'm thinking a broken valve or something
#3 is probably worn piston rings, valve seating issues or something.
This is outside my area of expertise and I lack the special tools to perform this work. Does anyone know a reasonable shop in the southwestern Ontario area that could do this type of work? Can I take it to a regular mechanic or does it have to go to a marine shop?
Any idea what type of price tag I'd be looking at?
Thanks,
Trevor.
Cylinder 1: 3psi
Cylinder 2: 150psi
Cylinder 3: 120psi
Cylinder 4: 150psi
Thanks,
Trevor.
