Neilmac
- Joined
- Sep 1, 2010
- 5
Hi,
I have a Volvo Penta AQ175A with a DP290 out drive.I have been running her thru the winter in the harbour to keep the batteries topped up but after running the engine I get about 4/5 galls of water in the bilge. I can hear it dripping from somewhere right below the rear of the engine were it joins the out drive but cannot see it with a mirror or a borescope! Once pumped out it does not reappear untill I run the engine again so I assume it is raw cooling water leaking back after running the engine but where is it comming from ? I discounted the bellows as this would be a constant flow so I am thinking it's where the cooling water is supposed to exit through the transom and the out-drive any suggestions gratefully appreciated.
Regards
Neil
Regards
Neil
