volvo penta aq211 w/ 290 sp outdrive
jfalco
i have a 1988 steigercraft with a aq211 with a 290 outdrive, the engine is a gm 305ci, how do i know what the outdrive gear ratio is, i have been serching for a replacement but i need this info, also is there a better way to go when its time for replacing, the engine and outdrive work perfectly but are getting up there in age, may consider new repower next winter
Don S
Re: volvo penta aq211 w/ 290 sp outdrive
If you have a single prop outdrive, the gear ratio should be 1.61:1
if you have the DP, it's a 1.95:1
captmello
I suppose you could look for used parts, but I would put my money into maintaining what I have. If you take good care of your current drivetrain, it should last for a long time. The 290 was a great outdrive. Parts are available...
john1970
I have a dp-c outdrive and mine was stamped were the annode ring would sit on. Mine is 2.30.1, the 290 and the dp-c look alike
jfalco
sorry for the delay on my repost but im in connecticut and this weather is killing me, Thanks for the responses i may be overthinking as usual, like i said boat was always maintained and everything works perfectly, i was just thinking ahead if something were to go wrong and the way it sounds a repower with existing 290 outdrive is ok. im thinking of going with a fuel injected engine next time and even if the hp is increased i dont drive the boat hard, usually around 2900 rpm, thanks again and im going to stop worrying about it
