Volvo Penta ecms
Guy on another forum setup with holley sniper using separate coils
I really like the sniper..... People pulling off perfectly good Holley carbs and selling them cheap to put on a sniper.
Cadillac66
I’m
To get the Gev VII motor to run on a carb.
Get aftermarket intake. (Dart, World Products, etc.). Send out to get the intake epoxy lined or put a heat exchanger on the motor. Pull oil pump drive. Install SBC/BBC distributor. Slap on a 850cfm carb. Set base timing to 12BTDC. Go boating
If you want to make a lot more power, swap the cam as well
do all the factory gauges run through the ecm ? And then run a low pressure electric fuel pump?
Gauges can be either analog (direct to sensor) or digital via NMEA
Yes in the fuel pump
