Volvo Penta Engine Cooling Problem
motoXracer01
Re: Volvo Penta Engine Cooling Problem
Nope, the belt is around the crankshaft and the crankshaft is what turns everything else, except the raw water pump. It's driven by the crankshaft.
Oh ok. Well I wont be able to check the model number until tomorow morning so when I find that out ill post it on here so you can see what you think. Im going to buy a new impeller anyways since it hasnt been replaced in a couple years and then ill run it in my driveway with the hose attached to it and if that still dosnt fix the problem then you can expect me to be back on here tomorow morning. Thanks for the help!
motoXracer01
What way does the impeller spin while running?
