Volvo Penta GXI 5.7 DPS, Question
Tea Bag
This is an I/O motor 280hp. My boat mech split and i have to do a few things to accomplish before the season. I need to replace the impeller and do a gear lube. This motor is on a 1999 Chris Craft Express Cruiser. Can someone please provide a link to some instructions on how to perform these 2 functions. Also is there any other maint you suggest before i put it in the slip. I have already done a oil change. Thanks for the help
Don S
Re: Volvo Penta GXI 5.7 DPS, Question
I have links to manuals for them, but really need to full model number or even a serial number for your engine to make sure it's the right ones.
Tea Bag
thanks DON S , I just went out and scraped the corrosion off the name plate. S/N is 4112058325 , prod no 3868913, type DP-SM :)
Don S
Your engines full model number is 5.7GSIPBYCCE
The BY is what indicates model year, which is a 98 model engine and drive.
You might want to look for the engins serial number, because the one listed for your boat doesn't show as a good SN, but the spec number is fine. Not a big deal since it's out of warrenty, but something that might be nice to have later on when finding parts.
Here's the link to the engine manual that should cover the water pump impeller
http://www.4shared.com/account/file...51_BY_Engine_Manual.html?sId=mSmlMxaqiwWm6WmZ
And one for the outdrive.
http://www.4shared.com/account/file/50982625/e2bdb42c/SX_DP-S_Service_Manual.html
Tea Bag
Thanks DOn, so your telling me they put a 98 model engine on a 1999 boat ?
Tea Bag
Don , can you tell me if this s/n is good 4112056325?
slasmith1
most boats have an engine that is 1 year off from the boat because manufacturers buy thier engine packages in bulk for a production run and then build the boats.
Don S
Yes, that is a good number, but it's for the outdrive, not the engine.
chap-happy
Hello Don, by chance could you help me out as well? I have a 2007 Chaparral with at 5.7 GXI. I am looking for a manual to do basic maintenance such as impeller and trim sensor adjustments. The serial number on my paperwork is 4012206693. From this could you tell me what flavor my motor and drive is?
Many thanks in advance.
IVAZ
Welcome to iboats.
Start your own thread for your question. You should also have a look at the "adults only" sticky at the top of this forum. Good luck.
