volvo Penta model 100
balzer_brett
Hey there i just picked up a 1970 Pere Marquette, with a 130hp volvo penta..... My question is the out drive shifts with the cable, but the outdrive spins in forward consistantly. I am new with boats and especially i/o any help would be great.
brett
TowRoper
Re: volvo Penta model 100
the prop spins fw in rev also? is it really doing that or does it just appear to be?
balzer_brett
I am positive it spins the same way no matter what gear is selected.... So i was thinkin, is it possible it is just from sitting?? the boat has been sitting for years(5 maybe more). If so would it be dumb of me to fill it with good oil and put the muffs on it and let it run in the garage for awhile?
captmello
Changing the drive fluid could also give you an idea of what condition the drive is in.
It sounds like you've had it running already. If your going to run it, make sure its on muffs and change the impeller in the raw water pump. Watch the temp.
Are you sure its a 100? I've never seen one.:rolleyes:
Post a pic if you can.:) engine too.
There's a few guys running around with aq130s on this forum.
balzer_brett
ok guys i could be wrong. the motor is a aq130, but the shop manual says in handwriting that the outdrive is a model 100... so i assumed they did the research but maybe not. Anyways i ran it today with water for quite some time and i think i figured it out, time for a rebuild. It looks to me like the shaft poked through the top cap(see pics).
TowRoper
ouch! didnt see that one comin :eek:
Gene70
You need to rebuild the upper gear. Contact Volvo for parts. They will give you the name of someone that has obsolete parts.
