Re: Volvo Penta NEMA 2000 ?'s
good luck
only reason I knew anything about the interface is last spring we had a new diesel rig come in, I dont do diesels
, but the drive was the new DP-G and from the factory the drive bellows hd been installed upside down by a tech that cant read and it was torn.
the dealership was in south carolina and the boat was in wanchese NC.
volvo contacted us to repair it.
while it was there the owner asked about adding the new NEMA stuff to his Furuno. thats when I found out even Volvo doesnt know much about it.
about all we could find out was the parts were going to be something over 2000 dollars and no one was quite sure of avalibility and compatability.
rhinda makes some excellent programs, you may find the latest hand held scanner to be as useful as the laptop.
you may also wish to invest in a Fuel rail presure test set.
most issues I have with MPI are fuel related and wont show up on the scanner or laptop.
biggest one is debris in the presure regulator screen, will boost fuel pressure to 80-90 PSI and cause a very rich low speed running condition.
