Volvo Penta Outdrive makes grinding.........
mr. b
I have a Volvo Penta outdrive and when you put it into gear it grinds forward and backwards and will not move. Any ideas............
Thanks
Don S
Re: Volvo Penta Outdrive makes grinding.........
Drain the gear lube and check the magnet for metal shavings.
Reel Poor
Drain the drive lube into a pan and inspect the lube oil and magnet on the drain plug for metal fragments. If you see metal bits/chuncks and the lube smells burnt you will need to remove the drive for disassembly and inspection.
