Volvo penta outdrive
64mac
Anyone know if you can swap complete outdrive # 3868896 w/2.18 gear with # 3868895 w/1.97 gear on 3.0 L engine ?
Thanks in advance..
BRICH1260
You probably can but you may have to change prop pitch to achieve desired results.
Horigan
Drive ratios are tailored to the engine peak torque and horsepower. The 1.97 is likely aligned with a 4.3L motor. If you change ratios, you need to change prop pitch so don't over or under rev the engine at WOT.
64mac
Thanks to all that answered. Was hoping to hear that.
