Saline Marina
Thread starter- Joined
- Sep 9, 2014
- 162
So I am aware of GM ending production of the 4.3L ironhead engine this year. I've read about friends over at Merc developing their own 4.5L V6 (sounds costly and I'd personally wait a few model years to work thru problems in design & mfg). I was wondering if anyone knew about Volvo's plans for their V6 in the future? GM does have an "LV3" 4300 V6 which is still a pushrod cam-in-block engine, but its an engine that I think is basically adapted from the 5.3L/6.0L/6.2L V8s with aluminum heads and the cam hardware for the high pressure direct-inject fuel injection, also featuring "active fuel management" which is a system to hydraulically disable the valvetrain of certain cylinders when their contribution to loads aren't needed (in the name of fuel economy).
I did some research on google and came up with essentially nothing. VP could have bulked up on inventory of the old 4.3L ironhead to presumably make it thru one or more model years but I was just curious if the new generation of pushrod GM engines was going to make its way into boats. I would think the fuel economy stuff like DI fuel injection and AFM displacement disablers would be unneeded and unwanted complexity in a marine engine. The aluminum heads would likely drive closed cooling.
Anyway, thanks for info, always curious about the direction things are headed.
Edit: so I did find this VP-380 (380hp!) which I think is a current production GM small block V8 similar to above.
http://www.volvopenta.com/volvopenta.../V8-380-C.aspx
Truck engine equivalent, I think...
http://www.gmfleet.com/chevrolet/sil...g_box_drw.html
Here is the LV3-V6 specs if interested. (285hp!) Although the Direct Inject adds some HP, could be balanced by the lower restriction of the marine exhaust manifold system.
http://gmauthority.com/blog/gm/gm-engines/lv3/
New engines all have piston cooling oil jets (basically a little tube sticking up into each bore to just miss the path of the conrod, constantly spraying oil on the bottom of the pistons) to enable higher compression ratios and the larger heat-release of the direct-inject combustion event.
More: L86 = 6.2L and could be VP-430
http://www.ls-guy.com/l86/
http://www.volvopenta.com/volvopent...matic/c_gasoline_sterndrive/Pages/V8-430.aspx
