Volvo Penta V8-270 5.0l in Cobalt fault codes.
Status
Not open for further replies.
Antoniomella
Hello, how are you?
I have a cobalt with a 5.7 gi year 2011
Hace the same codes spn 697-698-699
And also the spn 924
Some times apears spn 1213.
But the boat run normally and you can use it without problems , the thing is that when yoy
Give contact to the engine apears the check engine light and beep 3 times .
Anyone knows how to repair this spn924?
Attached the scanner codes
Please need help with this
QBhoy
Hello, how are you?
Hi. If I understand you correctly, if you’re saying the engine runs well but shows some fault codes when plugged in or on diagnostics??…
I don’t know specifically for the VP version…but I do know the same engine in mercury form has faults flagged like trim sender. Steering, pitot and one or two others…because it doesn’t have those sensors fitted and or networked to the system.
If your 5V is low, it will cause all kinds of different codes
Check the 5V and verify it "is" 5V
Status
