Highlancer
Thread starter- Joined
- Jul 9, 2021
- 5
I have 2005 Monterey 214FS
This started with hesitancy when shifting into reverse, the rpm's would increase enough before it shifted that you would hear a "clunk" when it engaged. I avoided reverse after that happened, but then forward started having different issues, it shifts immediately into gear, but it seems like it's not fully engaging. e.g. previously when pulling up a wakeboarder you would get to speed very quickly, now it takes a lot longer to finally get up to speed. It seemed logical to me at that point that the cable(s) probably just needed adjusted, but I checked the throttle cable at the engine, it is hitting the stop when the shift lever is fully forward or in reverse. Pulled the cover off the outdrive and again the shift cable will fully engage either way. I checked the lower unit fluid and it's crystal clear (changed recently) and at the halfway mark. There is some slop in the mechanism as many have observed, but doesn't appear to be anything significant. The cables seem to be moving well, so I am scratching my head and googling everywhere to determine what to troubleshoot next, bad shift cones? The boat had ~200 hours on it.
I'm just a year into boat ownership, so I am not as educated as I would like to be yet. Appreciate your help!
