ghaunhorst
Thread starter- Joined
- Aug 14, 2007
- 7
I have a trim limit control unit (black Box) #3851584 / 3855584 on a volvo penta outdrive type SX-MHP that appears to be faulty. Does anyone have information/instructions on how this system is supposed to work, have a wiring diagram, or know how it can be tested? I have tried many things as noted below and it seems that this box is the problem. But it is too expensive to just swap it out and hope.
The following should help answer some questions:
Metal Plaque on Engine reads: Prod. No. 3868850. Type SX-MHP. Serial No. 4111505473.
Have examined and tested the Pump, Motor, Relays, Cylinders, and filled reservoir. The outdrive moves up and down just fine if I apply 12 volts directly to the relays.
I have ckecked fuses and connectors. Measured resistance across sender contacts and it changes as outdrive is raised and lowered.
When moving the trim switch on the throttle, the lights on the black box light up but nothing else happens. So it seems the box is getting the signal from the switch but the signal is not getting to the relays.
Any info or suggestions would be appreciated. Thanks , Greg
