wkb2460
Thread starter- Joined
- May 4, 2008
- 146
I have a 2000 Volvo SX-M drive. The output shaft seal is leaking as was indicated by gear oil in my drive bellows. I have been reading the volvo manual on this repair and it mentions a pretension crush sleeve between the gears.
Question: Do I have to replace the crush sleeve if I am only replacing the shaft seal? I understand I should use a new Torx nut on the gear, but if I am reading it correctly I don't have to replace the crush sleeve if I don't take the bearing assembly apart.
Any help with this repair would be greatly appreciated.
Thanks
Thanks
