jclarke2899
Thread starter- Joined
- Mar 23, 2009
- 72
Ok so maybe I'm missing something here, but I keep reading how easy it is to replace the shift cable. My boat is a Four Winns Horizon and I wanted to put in the Teleflex Extreme cable. There is no room to work behind the control and I have small hands. Is it that people usually just replace the inner cable and not the outer core? If that's the case then I understand how that is so easy. Is it worth this trouble to use the Extreme cable? There are existing cable ties that I will not be able to reach to remove so I'm thinking I will cut the old cable to remove it from where it goes through the transom and use new ties throughout the length of it. Will I encounter any problems getting through the tube at the transom, it just slides through right with no fittings? I'll then connect it in the rear of the drive and secure in anchor block. Any thoughts? Thanks!
