Don S. Please help!!<br />I have been blowing 10 amp fuses from my trim switch. I came out of the lake and could not get my lower unit up, kept blowing fuses as soon as I got near the cradle. Someone told me to wrap the fuse in foil and it worked, was able to raise my lower unit to trailer home. Today I traced the wires be on the back side of the motor and found the bare wire touching metal. I repaired the wire, hooked the battery back up and nothing after replacing the 10 amp fuse! Could my 2 relays be shot and how can i check this? You said previously the 10 amp fuse controlled the 2 relays. Please help, Thanks
