Vortec drain plug?
ugbandtulsa
I have 2 newer 350 vortec chevy's. Can anyone say with certainty how many drain plugs are on these motors? 4 each?
Thanks, Mike
Don S
Re: Vortec drain plug?
Gee, don't ya think it might help to know what Make (Volvo, Mercruiser, Marine Power, Kodiak) it is, maybe what year, carbed or fuel injected, raw or closed cooled, a full model number, not just a HP rating or it's a 350 Vortec.
What drive. Any accessories added to the cooling system, are you draining oil, water, what?
Just some of the things that makes a difference.
ugbandtulsa
Well Don, I'm not draining the carburetor, or the fuel injectors. Also, since it's winter I'm not doing a routine oil change. And, if it was a closed system, I wouldn't be draining it most likely, now would I? I'm sorry I don't have the serial number of the motor. Just asking a very simple question.
Don, I love ya, and you obviously know a ton about boats, but I wish I had a dime for every time you ask for a serial number on this site, or your responses seem just a bit snappy. So, 350 vortec, block plugs? Anyone besides Don I guess?
Thanks, Mike
Don S
There are 2 block plugs. But there is more to it than that.
If you are the type that wants exact answers to vague questions, You are starting on the right foot.
I would sure hope you would be wanting to drain the raw water side of the system......... Wouldn't you
Ayuh,.......
Here's an Exact Answer to the Vague Question........
The Vortec Block has the Exact Same Drains as the SBCs have for the last 40+ years.......
tommays
And you might have the volvo Gm with the intake manifold that has a special draining procedure BUT why worry :)
Tommays
DHPMARINE
A few years back we sold a new motor to a new customer.Customer's former Dealership's salesman said "just pull the bilge drain plug and keep the bow high.It's self draining".
I wish there were more salespeople like that.But maybe the customer asked how to drain the boat,not how to drain the engine.
The best answer to how many plugs ......
ALL of them !
DHP
Gary H NC
LOL DHP, thats what keeps you with repair work.
I wish a I/O was that simple....8)
180shabah
Well Mike, did you find all of your plugs?????
ugbandtulsa
Yes, I think I found them. Using Don's answer of 2, and careful searching, I think that was it. I did also drain the manifolds, and the cooler. Sure got alot of water out of there, and I did pull the thermostat out and filled all the lines and the block up with AF. Thanks!
