mohead1
Thread starter- Joined
- Jun 18, 2011
- 134
Ok, Im back with some more wonderin's.....over the winter, I want to upgrade to a Vortec top end on the '88 260 Alpha in my Wellcraft. I keep hearing alot about the dished pistons and whatnot....
So, I want to put on the upgraded Vortec heads (valve springs, guideplates, set up for more lift), intake to match (prob one of those aluminum hi-rise with the brass inserts), mild cam (268 dur. around .460 lift), and prob change the Quadrajet to a marine Holley (600 cfm awta do it).
I was running some compression numbers, trying to guess at the ratio if in fact I have dished pistons. Was using two variables on the piston dish, one at 8cc and one at a guessed 10cc. With a 64cc chamber on the head, .010 deck, and gasket I guessed at .025, it comes out to 9.5 +/- C.R. With the little more cam it will bleed some of that off, so what is the issue?
On hot street cars these days, the youngsters are putting mini chambered heads on and using a piston dish to make the ratio size to work. I havent had the heads off so unless i buy a borescope, I dont know if I have flat tops or dished.
Someone wanna chime in here? If Im using 93 octane fuel, does detonation really come in to play here? I think not, hell I have run 10.5/1 in street cars w aluminum heads, stiffer gearing, and no issues....
