kewlkatdady
Thread starter- Joined
- Sep 12, 2010
- 188
I'm replacing the motor in muh boat due to water in the crank case...
I bought a long block from Rapido...
The old motor has metric bolts on the back and motor mounts, and the long block from Rapido has standard bolts...not sure if this means anything or not...seems weird that a GM motor has metric when most are standard...
anyway on to my question...
What is the difference between Vortec and Non-vortec heads...the heads that came on the long block has stamp rockers and the heads off my old motor has roller rockers with a rocker rail...should I try to convert the rocker rail and roller rockers over to the new motor or just go with the stamp rockers and keep the Rapido warranty in tact.
Thoughts?
Thoughts?
