stresspoint
- Joined
- Sep 19, 2022
- 1,048
the few times when i have seen this happen on V8 Vortec motors .may be common on the 4.3, however nearly never happens on the 5.0 or 5.7
(i have had my fingers on many a 5.7 and 5.0 motors ,FYI, i have a 5.7 Vortec ""i personally built"" that has close to 500 reliable and driveable hp in my toy boat
i can tell you ,it does happen on V8s (not only Vortec ) as well you have just never seen it, where as i have.
each diagnostic , the gasket leak travels to the second bolt "in ", the water track goes from there down to the intake runner , not a lot but enough to cause intrusion.to the cylinder over time when the motor sits, each time it was apparent when the motor had a miss fire from start up after sitting . as Op describes.
the easiest way to determine if this could be the issue is to remove those 4 inner bolts starting with the 2 toward the front of the motor and check for sign rust ,
guessing as i am no xsput on all matters ,no rust on the bolts would mean that OP needs to start looking elsewhere.
either way its going to be head off to resolve this problem .
