VP 8.1 Gi-B rebuild
Silverbullet555
I'm preparing for some transom work on our boat and the motor will be coming out as part of that work. The engine and drive (DP-SM) have about 350 hours on them and I figure now is a good time to freshen it up and replace items that might be going bad in the near future.
What parts should I be looking at replacing and what services should I be looking to have done (i.e. valve job), etc.
Just preparing myself for what is coming and want to be ready for it.
As much as I don't want to have to do the repairs, I am looking forward to having great access to the bilge and to the motor to do work, etc.
Re: VP 8.1 Gi-B rebuild
Ayuh,... That motor should be good for another 1000 hours before it needs freshening...
A Compression test might point out any Issues though...
Silverbullet555
That's what I am hearing which is cool. Going to check the teeth on the flywheel to make sure they are pristine, the coupler, hoses and do a compression check. I will be able to compare those results to the compression test done a couple years ago.
Don S
One note on the compression test. DO NOT do the test on an engine that has been setting for a while.
A leakdown test will give you more information than just a compression test if you REALLY want to know the condition of the engines.
