I have a small leak from the drain screw after changing the gear oil a few weeks ago. I'm pretty sure I have the right o-ring (part number 955981) and I also ordered a new drain screw and set of o-rings. Same problem. Tightened screw to spec according to workshop manual. Any ideas?
I also wonder why the groove is bigger than the o-ring (image shows old my old drain screw). I tapet the treads with electrical tape before sliding on the o-ring so it should not be damaged.
