VP Impellor 875575
kamby
Ok, i found my impeller that i need to install in my AQ125a. I checking online and when i key in that part # i dont get my engine number listed as compatible. On the volvo penta site it lists that number under maintance parts, but doesnt mention my engine on the list just the 125b.
Is this the right part # before i put it in. It seems like its slightly smaller than the one i took out width wise and blade size, the old one coulda have swollen though. The shaft hole and key way measure the same.
If this isnt the right one that what is the right one. The one in there was a johnson 801 or somthing like that. The replacemetn i want to put in there is Volvo Penta 875575.
Also looking at the front of the engine what direction does it rotate so i can put the fins the right way, cw or ccw
Thanks
Jason
captmello
Re: VP Impellor 875575
Thats the right one. The 125A and B take the same impeller. The impeller will go either way.:)
Don S
875575 is the correct number of the impeller for the pump that came with the engine.
Twist the impeller clockwise when installing it.
kamby
Thanks for the responses guys. Before i patch it in, whats the paper gasket for. When i took the cover off it had just the white one
Don S
The impeller is used on several different engines, it comes with gasket for other pumps. One impeller kit covers them all.
kamby
Ok cool, Thanks So much Don S and CaptMello I appreciate all your help.
