VP Trim sending unit connector replacement
ChrisCraftFan
I got my old sender out and the new one in. How is everyone swapping out the new leads into the rubber connector? the book shows special tools used to push them in and out but i cannot find those tools anywhere. Just wondering if anyone has a "trick" to getting the new leads into the rubber connector inside the boat.
dypcdiver
File down a bit of round steel of even a 3/16" bolt to give you a 1/16" dia tip 1/2" long and just push them out.
GeorgeDes
Others have used the rounded handle end of one of those small metal files you can get at Harbor Freight.
muc
"Retired" Association of Marine Technicians...
use rubbing alcohol as a lubricant. it really helps.
ChrisCraftFan
I was looking at the manual to install the new sending unit. It indicates that I need to check the ohms when down. I am not sure what the reading means? So in the manual the Plus and minus are on top of each other but for 11+_1 does that mean from 10 to 12 or 11.1?
ChrisCraftFan
fetch
muc
It means 10 to 12 ohms
Once everything is back together. Use the trim gauge to fine tune it. All trim gauges are just a little bit different.
cptbill
That's the way I've always done it
Lubak572
I am thinking of just eliminating that black plug all together. I may just properly butt splice them. I have 3 wires from the sender and only 2 wires on the engine side. How should I wire them? I have analog guages.
