VP Water Pump Pulley
Hvymtl
I'm having a hard time finding a replacement 2 groove water pump pulley for my 1999 VP 305 GM engine.
Mine is a two groove and measures 7.25 in diameter and is 3 inches deep. Could I go to an aftermarket that measures 6.50 in diameter and just change the belts or will this affect cooling too much, or any idea where to find a new or used one that isn't 120.00???
dypcdiver
Re: VP Water Pump Pulley
Do you mean the raw water pump or the circulating pump? If it is the raw water then it comes as part of a new pump and you might find someone who has replaced their pump and has one hanging around.
I see it is 3" deep so assume it is not the raw water. Info might help someone else.
Hvymtl
It is the pulley the water pump not the crankshaft
Hvymtl
That one is a single pulley - I need a dual. Sorta hard to find.
bruceb58
The one I showed should be a double. You can ask the seller to know for sure.
