FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Re: VRO 1987 90HP EV - what are the necessary steps to disable ?
After doing this, I was careless and the 2 wires going to oil tank crossed. The warning horn sounded to inform me. This is corrected now. Will there be any other repercussions such as kill switch issues because she didn't want to start after this (maybe flooded ???) ?
There should not be.
You should seal the ends of the VRO amphenol plug so that it can be reused later if desired and to keep them clean.
You should test your overheat alarm wiring by grounding the control ends of the tan wires at the cylinder heads to be sure that the circuit is intact. The ignition switch must be in the run position to test.
Not sure I explained correctly. The 2 (disconnected)wires that go FROM OIL TANK TO ENGINE, ends were open and contacted each other while engine was running for a second or so causing the horn to go off. I already had disconnected the amphenol (black, gray and tan) fron fuel pump. Could this affect kill switch or a fuse ?
