1999 Johnson J115PLEEM 115hp. I'm removing vro pump and installing a 0438559 fuel pump with external pulse. The fuel outlet on the vro is not a hose connection, it has a fitting that just stabs into the fuel component bracket. How else can i connect the fuel outlet from my new pump which is a standar 5/16" hose connection ? The fuel component bracket has the primer solenoid integrated in there somehow. I've read other posts where the vro had all hose connections, guess mine is different.
