Piece715
- Joined
- Jan 26, 2009
- 757
Ok... I went out and tried to test fire the motor yesterday. When pumping the primer bulb i noticed that there is a gas leak in the engine. The leak is at the seam of the housing of the VRO pump We had the motor running for about 10 sec before it died.. Started again and prob 5-8 sec run and can't get it started again. The primer bulb doesn't stay hard so I'm guessing where that leak is happening is putting too much air into the system and the motor is starving itself. Take a look at the vid and see if this is something i can fix.
I have posted this in my restore thread and in a thread I have on a mystery wire I had spliced into the hot horn sensor wire (tan) coming from red throttle plug
I have a found a good link to VRO history: The VRO Story
My motor 1985 Evinrude 50hp long shaft (E50BELCOB) has been switched to premixed fuel (50:1) prior to me owning her. In the picture below you can see the green plug where the oil inlet has been plugged. Also notice in the picture that the housing of the VRO pump doesn't line up. Is this typical? or did the shop that worked on my motor last mess it up... (like the other things i have come to find out i was charged for and never performed)
I have read that the oil side of these pumps cannot be rebuilt but the fuel side can be. The main problem with rebuilding the pump is that it usually stems from the housing being warped but to me it looks as if its just flat out missing the gasket between the two housings. Does anyone have any experience with this and can help me out... Thanks in advance! Right now this is the only thing from keeping me from my initial splash after 3 years worth of work!
