VRO fitting replacement
bennnyjw
hello i have a 1986 110 hp VRO. Im running a 50:1 ratio. But i recently had a fuel line split ans while accessing it a fitting on the bottom of the VRO pump assembly broke off. Can i order a new fitting? Or something cheap to replace the pump?
There is a spot on the intake manifold to mount a pump directly over the pulse port.----Found just in front of the starter motor.
jakedaawg
That's a ridiculous amount of money to spend for that pump. What a kit, a hose 4 cable ties and a 58 dollar pump....for 158 plus shipping?
just go to the dealer and ask for a pump from a 88spl circa 1990. It'll be fine
Faztbullet
You have a OMS pump...the fitting is part number 0340186and about $8
bennnyjw
Ok so one last bit of advice needed. I have the replacement pump. It has in, out, and pulse? Do i still use the old plastic T the vro used? Is the long fitting from the block the pulse? Do i plug that off?
Having the two carbs connections and the small plug is throwing me off.
