bonz_d
Thread starter- Joined
- Apr 22, 2008
- 5,276
Hey folks looking for info of help.
I have a 1987 Johnson 50hp that has been sitting in my garage for awhile now that I'm finally going to get to. The history on this one is that I'd picked it up as a parts motor because it had a complete working tilt and trim unit on it that I wanted. It had a blown out clutchdog in the lower unit and was also told it had low compression on one cylinder. Paid what I thought was a fair price for a working tilt unit.
After removing the tilt n' trim I had this on a stand and curiosity got the best of me. So I hooked up a battery and did a compression test on it. Top cylinder was marked with a paint pen as 140 and the bottom was marked as 130. What I got was 142lbs on both! So I then proceeded to connect some fuel to see if she'd fire up. Low and behold, 1st try and it was running but wouldn't stay running.. Run 3-5 seconds then it was like it was out of fuel. I also noticed the VRO was disabled. Anyways that was that and I started watching for a lower unit.
Well I finally got my little fingers on a nice lower for it and have it installed. Tried running it again today and same results. Like it runs out of fuel. I've got the top carb off and the gas that came out of it reeked. So I will be rebuilding both this weekend. Removed the VRO pump and the gas looked fresh and didn't smell but and uncertain if it's functioning.
The question I have is will a fuel pump from an 1980 50hp fit? I know there are conversions out there and that it can be done but can it be done using this pump? I've been searching the internet and seem to come up with many conflicting ideas as to what will work and what wont. OR I'm just confused and am not following correctly.
Right now my intention is to just get it running so I can go thru it more thoroughly and then to replace the VRO to functioning again.
