I have a '91 70 HP 'Rude.
Last fall when I brought the boat/motor home, I did a MASSIVE tune and inspection before putting her to sleep for the winter. All good compression all even 120 PSI.
Ran her @ all summer on the St. Lawrence River, maybe most running time at a shot was 45 minutes er so,(I'm easy on the throttle never past 5000 RPM, nice easy ramp up to speed too. I'm not out there to race, just fish.
Fall is here, I got a free tow to get her home, (a few weeks early, but,WTF, it's free).
Don't have too much to do to the boat this fall, clean her up, move batteries to centralize the weight, new bow trolling motor fish finder.
But the VRO?.....
I did a test on it last fall, (got the specs somewhere,maybe here, pumping cap.).
Was good.
How long can a VRO pump last (I don't use E fuel, non E high test from a land pump, Sea Foam additive)??
It looks like the pump is orginal from '91.
$300 and some change is expensive, but to have it sheet the bed on the water, well that makes the cost seem easier to swallow!
I don't want to remove it, hobb in a cheaper pump and mix fuel as I run my Honda 5 HP 4 stroke off the same spin on fuel filter and main tank.
I don't want to add a tank for the Honda as room is limited in the boat and it's just another fuel system to keep an eye on.
Should I change it? Should I leave it alone?
Thoughts? Ideas? Jokes?
Joe
Many times I'm too anal and worry about stupid stuff!
But the VRO?.....
Was good.
Joe
