Sea Rider
- Joined
- Sep 20, 2008
- 12,345
Saw on the net a pair of cracy Russians clean almost everything they used with W-40. My 450 Rib which is taken out of water after its use, began to develop a rough hull at touch along green mould scale build up after one year of constant use. So what the heck, sprayed the full contents of a small W-40 can on entire hull, let soak for 5 minutes, wipped the entire hull with a non abrasive plastic sponge pad. Bingo, hull Issues were removed fast while pad was being wipped through. W-40 made a great job, hull is shinny & smooth to touch, disperse water more efficiently than before and Rib has gained slight more top end at wot.. W-40 has my vote.-
Happy Boating.
Happy Boating.
