NooBoarder
Thread starter- Joined
- Jul 30, 2013
- 7
In short, I just purchased this boat that came with a mirage plus stainless 3 blade 19P prop that I believe is 15.25" diameter. The boat runs great with trim tabs but for wakeboarding I pull them up to get a nice wake and the boat struggles to get on/stay on plane. I'm not concerned with top end at all so I bought a 4 blade prop of the same pitch 19P 14.25" diameter. Now if I'm not carefull I can get the prop to 'slip' and the rpms will shoot up without any acceleration and the hole shot is only marginally better at best. Is the diameter change that big of a deal? I couldn't really find a good 15" diameter 4 blade 19P prop.
Boat
2001 Starcraft Nexstar Mach II 1910 GT
Engine
Mecruiser 350 MAG MPI - 300HP -5200 Max RPM's WOT
Boat would do about 60 mph at 5000 rpms ( I think it was) with stock prop - 3 blade 19P 15.25" Mirage Plus S.S.
OutDrive
Bravo One
In summary, I don't think my prop is turning enough water for the size/weight of my boat even though I kept the pitch the same. Do I need more pitch, bigger diameter, or is there some other detail of design I'm overlooking.
Thanks in advance for your help!
Boat
Engine
OutDrive
Bravo One
