aintmisbehavin
- Joined
- Apr 20, 2008
- 53
Re: want more top end
why would this reduce life? does everyone run their boats at WOT at all times. Its a 76 johnson 115. Not sure how much life it actually has left anyway.
Compression is 120 +/- 5 on all cyl
Ignition, plugs, battery and everything is good
Fuel pressure is good.
Boat is running great, just want to do a little tuning. Had no idea how to set a outboard up.
If your motor is only turning 5050 @ WOT, you can expect significantly reduced life. I would try raising the motor first based on your other thread before buying another prop.
