want to make a vacumn and pressure tester for lower units
bob johnson
instead of me spending a day trying to look it up... or go and try and figure it out at home depot or lowes.
has anyone made one they can tell what parts they used....
I am thinking two ways...i could make a fitting that i attach a quick discconect air chuck to that screws into the lower unit against an o ring.
then i get a pump and attach a male air fitting to the hose coming out of it..
then attach the two air fittings and pump up to maybe 10 psi...then detach the pump and plug in a gauge that also has a male air fitting..
i might loose a little air on the exchanges...
but i could just sit and watch the guage at that point
the other way would be to build it all in one unit.....and i could read the guage that is mounted on the pump....
hope to hear from someone
thanks
bob
DamianJP
Re: want to make a vacumn and pressure tester for lower units
Get a fitting that you use to plug into the L/U for installing new gear lube, and splice it into a bike tire style pump either the one you use your foot to inflate or a 12v one. Of course ones with a built in gauge so theres no changing or swaping.
Then watch the gauge to see if its leaking and/or use soapy water around known problem areas to see bubbles (leaks).
http://www.google.com/imgres?imgurl...ty=98&sqi=2&page=1&ndsp=74&ved=1t:429,r:2,s:0
DamainJP
dew2
I have a 12 V emergency air compressor with a regular valve stem from a wheel.I hold the valve stem in the hole and flip the air compressure switch with my foot,When it hits 10 lbs I use my foot to turn the air off while I'm spraying dishsoapy water and just hold the valvestem in place.Works great
oldslowandugly
I used a 1" piece of clear plastic tubing and just sort of threaded it into the oil filler hole so it cut it's own threads. Then I took an old car tire stem/valve and scraped the rubber off, down to the brass. I jammed that in the plastic tube and hose-clamped it in there. Now I can screw it into the lower unit, and use a bike pump w/gauge to test the pressure.
Faztbullet
Mityvac MV8255 dual pump(vac & psi) and hose & fitting off Lubermatic gear oil hand pump from Wallyworld. Total investment about $65 and it fits in tool box!!!
bob johnson
I just bought a MIGHTY VAC 8000 brake bleeder-vacumn pump...and i already have a pump and hose for lower unit oil!!
Ill see how is works
I should be checking with the lower unit empty theoretically to check both the upper DS seal and the lower PS seal....right?
bob
