Want to Replace My Trailer Jack
Chris-R
I'm thinking of getting a better trailer jack for my 5 Star trailer. I was thinking of a SeaSense Big Wheel or something like that but want to know what others think. What trailer jack are you using? Thanks for your help.
Bob's Garage
Re: Want to Replace My Trailer Jack
Over the years I have found that buying a cheap jack is one of the biggest mistakes you can make.
I am glad to see that you are looking at a quality jack to support your "investment".
I replaced my original jack with a drop leg style, rated at 2500 lbs, with a plate instead of a wheel. My trailer and boat are 6500lbs, and it is usually parked on sand. The plate helps to keep the jack above ground, and I don't have to worry if I am sitting on a hard surface that has a slope.
I also used a 2x6 under the plate if it's being stored fore any length of time.
BigB9000
The plate isn't bad if your tong is light enough to lift by yourself.
if you have a 28' boat, and need to push it over 5" to get on the ball, they get annoying.
The expensive ones last a bit longer than the cheap ones.
issue with them is that plastic wheel weathers fast, and soon, isnt a wheel anymore.
My friend bought a new triple wide mobile home (or "manufactured home")
I guess its customary to unbolt the tongs of the things, and leave them with the new owner? Anyway. on that 12" iron I-beam of an A-shaped tong, is the largest, strongest, and best tong jack ever. Hell, its made to lift a 50' section of home.
Get one of those!
Oh, and you can turn the handle with your little-finger
Bob's Garage
With a tongue weight of 600 lbs, I can't pick it up anyway, and seeing as how it's in the sand, I can't roll the trailer if it had a wheel, so the plate is what works best for me. I just learned to back up to the coupler without having to move the trailer.
Seems like a trailer that can use a 1500 lb jack would be a little over-matched with a mobile home jack. Probably increase the trailer weight/tongue weight by double, lol.
BigB9000
Funny thing is, Its now on my single jet-ski trailer.
That jack has seen 5 trailers over the years.
Its held on with u-bolts. When the trailer gets a flat, I move it closer to the wheel, and jack it up. It rocks.
